Problem asgining key binding
How can i asing the ’ key as a shortcut? What i mean is the quote key, as in ’ ’ and “”. I want to press shift+’ (wich, in a normal writing block would result in double quoe, such as: ") and run a terminal.
The problem is, it wont work.
Key ' A S xterm
i think thats my binding (i’m sry, i erased it all and started a new config…my bad – but the issue still remains)
thx
  • BodyDrop -
Try
Key apostrophe A    S    Exec xterm
