DestroyFunc FuncAutoEnter
AddToFunc FuncAutoEnter
+ I Autohide HiddenConsole 500 250 W
+ I Autohide FvwmPager 500 250 E
+ I Autohide FvwmDock 500 250 S
AddToFunc Autohide
+ I ThisWindow ($0) Deschedule $[w.id]
+ I TestRc (!Match) Deschedule -$[w.id]
+ I ThisWindow ($0) ThisWindow (shaded) AutohideShow $1 $3
+ I TestRc (!Match) All ($0, !shaded) AutohideHide $2 $3
AddToFunc AutohideShow
+ I Schedule $0 -$[w.id] WindowShade $1 off
+ I Schedule $0 -$[w.id] Raise
+ I Schedule $0 -$[w.id] Deschedule $[w.id]
+ I Schedule $0 -$[w.id] Deschedule -$[w.id]
AddToFunc AutohideHide
+ I Schedule $0 $[w.id] WindowShade $1 on
+ I Schedule $0 $[w.id] Deschedule $[w.id]
+ I Schedule $0 $[w.id] Deschedule -$[w.id]
AddToFunc StartFunction
+ I Module FvwmAuto FvwmAutohide -menter FuncAutoEnter
and all of the 3 apps hide well BUT only one shows when i move the pointer on it (FvwmDock). I’ve noticed that it’s always the last i call in FuncAutoEnter that works well.
Can you detail a little more what you want to happen in each case? Do you want to schedule the auto{hiding,raising} to be at the same time? Do you want all hidden windows to popup when the mouse enters into either one of them?
I just want that when i move the cursor on one of those apps, the one i’ve pointed appears (not all of them, just this one). This actually doesn’t do that: just the Dock can raise, the 2 others stay hidden when i move on them… am i clear ? it 's difficult for me to explain in english.
I was having this same problem and have already spent a few hours having a headache over this… becuase I couldn’t recognize what the problem was … so i just kept rechecking everything
But the above solution finally worked!! Phew and thanks to Comete!
Suggestion/or tell me whom to tell, or tell me how to do it myself: Update the FAQ with the above solution. Coz I am pretty sure future fvwm users would go through the same grind.
