After reading the manual page (yes i did it ! ), i understood that if i use the style: “Style * NoIcon” and an IconManager then i must use: *FvwmIconMan: NoIconAction “SendToModule FvwmAnimate animate” to have animations when i iconify windows.
So, that’s what i did but i have no animation when iconifying but only when i deiconify from the IconManager.
I use Fvwm 2.5.16 but i have reproduced the problem with 2.5.14 and on two differents machines. I’ve tried to send the commands directly in FvwmConsole but that’s the same result.
This is some parts of my configuration, do you see anything wrong ?
DestroyFunc StartFunction
AddToFunc StartFunction
+ I Module FvwmCommandS
+ I Module FvwmProxy
+ I Module FvwmPager 0 3
+ I Module FvwmButtons -g 400x40+733-25 FvwmDock2
+ I Module FvwmIconMan
+ I Module FvwmAnimate
+ I Module FvwmEvent
+ I Module FvwmAuto FvwmAutohide -menter FuncAutoEnter
Style * NoIcon, NoIconTitle
Style * StickyIcon
DestroyModuleConfig FvwmAnimate: *
*FvwmAnimate: Color white
*FvwmAnimate: Twist 2
*FvwmAnimate: Effect Flip
*FvwmAnimate: Delay 6
*FvwmAnimate: Iterations 25
*FvwmAnimate: Width 3
DestroyModuleConfig FvwmIconMan: *
*FvwmIconMan: NumManagers 1
*FvwmIconMan: Resolution global
*FvwmIconMan: Background slategrey
*FvwmIconMan: Foreground white
*FvwmIconMan: Font "Shadow=1 1 SE:xft:snap:pixelsize=12"
*FvwmIconMan: ButtonGeometry 600x40
*FvwmIconMan: ManagerGeometry 1x1-720-25
*FvwmIconMan: ShowOnlyIcons True
*FvwmIconMan: DrawIcons True
*FvwmIconMan: Title "Icons Manager"
*FvwmIconMan: Colorset 61
*FvwmIconMan: IconColorset 61
*FvwmIconMan: SelectColorset 1
*FvwmIconMan: Format "%i"
*FvwmIconMan: NoIconAction "SendToModule FvwmAnimate animate"
Mouse 1 4 A Iconify
Thanks !
Comete
