Functions I write to the config file do not evaluate.
eg
DestroyFnc T1
AddToFnc T1
- I Exec exec -e man “fvwm”
evaluating this in FvwmConcole gives:
[fvwm][__execute_function]: <> No such command ‘T1’
If, on the other hand, I copy a function then rename it, it works OK.
As a test I take the function ViewManPage and add:
DestroyFunc RewrittenManPage
AddToFnc RewrittenManPage
- I Exec exec $[infostore.terminal] -g 80x40
-n “Manual Page - $0” -T “Manual Page - $0” -e man “$0”
DestroyFunc CopiedViewManPage
AddToFunc CopiedManPage
to the config file. The rewritten (ie typed in again) version gives the same error as the T1 example while the copy/pasted one works OK.
I am running Fvwm 2.6.8 on Debian 10.4.
I have this same setup running on another computer with the same results.
Help would be gratefully appreciated.
