hi
'trying to make a “design” theme ( sounds great hu ? ) :
i will share a soon as possible.
looks really good, nice and clean… but i dont really like your title decors =P
you should make them purple instead of gray
hi
well , they 're not grey but transparent .
As you can see , it’s a work in progress but no more progress since this shot , i have worked on my “winter theme” and learned some interesting things.
I will soon continue this one.
thx for your opinion
nice one
simple, and clean…
I like it. Good work.
Hey the titlebar buttons are mine ! (i’m pierreg from the gentoo forums ) But there is no problem ^^ I’m glad you like it
Nice theme
hi all,
@pierreg : yes do you missed it ? i was trying to make some with inkscape when i found yours , they are perfect
@Fajer : many thx
