Does anyone have any functions and a key binding like this:
dev.gentoo.org/~taviso/screensho … onsole.png
I’m using taviso’s config so it mostly works, still have some issues with it, but learning to decode this odd syntax
I’m just looking for a way to access the console in the same approach that Quake uses. Pressing ~ to get to the console.
Thanks.
lucky
2
Hello, i use these functions to do that :
[code]Key twosuperior A C ToggleTerminal
DestroyFunc ToggleTerminal
AddToFunc ToggleTerminal
- I SetEnv OpenedTerm “False”
- I None (GameConsole) StartTerminal
- I All (GameConsole) Focus
- I All (GameConsole) Raise
- I All (GameConsole, Shaded) WindowShade False
- I TestRc (NoMatch) SetWindowShadeTrue
DestroyFunc SetWindowShadeTrue
AddToFunc SetWindowShadeTrue
- I Test (EnvMatch OpenedTerm False) All (GameConsole) WindowShade True
DestroyFunc StartTerminal
AddToFunc StartTerminal
- I Exec exec $[TermQuake] -geometry 150x30+0+0 -shading 30 -name GameConsole
- I Wait GameConsole
- I All (GameConsole) Resize 101 keep
- I SetEnv OpenedTerm “True”
AddToFunc StartFunction
- I Test (Restart) All (GameConsole) Close
because of the console become unusable when you restart fvwm
Enjoy !
I have it working this way.
file = HiddenConsole
DestroyFunc StartHiddenConsole
AddToFunc StartHiddenConsole
+ I Exec exec xterm -geometry 153x10+0+0 -name HiddenConsole
+ I Wait HiddenConsole
+ I Next (HiddenConsole) Resize $[vp.width]p 9
+ I AutoHide HiddenConsole 0 0 N
DestroyFunc HiddenConsoleKeyBinding
AddToFunc HiddenConsoleKeyBinding
+ I ThisWindow (Shaded) FuncAutoEnter
+ I TestRc (NoMatch) NoWindow FuncAutoEnter
DestroyFunc FuncAutoEnter
AddToFunc FuncAutoEnter I Autohide HiddenConsole 500 500 N
Style HiddenConsole Sticky, WindowListSkip, Notitle, StaysOnTop, NoHandles,
Style HiddenConsole CirculateSkip, WindowShadeSteps 100, ResizeHintOverride
Key H A 4 Next (CirculateHit, HiddenConsole) HiddenConsoleKeyBinding
AddToFunc Autohide
+ I ThisWindow ($0) Deschedule $[w.id]
+ I TestRc (!Match) Deschedule -$[w.id]
+ I ThisWindow ($0) ThisWindow (shaded) AutohideShow $1 $3
+ I TestRc (!Match) All ($0, !shaded) AutohideHide $2 $3
AddToFunc AutohideShow
+ I Schedule $0 -$[w.id] WindowShade $1 off
+ I Schedule $0 -$[w.id] Raise
+ I Schedule $0 -$[w.id] Deschedule $[w.id]
+ I Schedule $0 -$[w.id] Deschedule -$[w.id]
AddToFunc AutohideHide
+ I Schedule $0 $[w.id] WindowShade $1 on
+ I Schedule $0 $[w.id] Deschedule $[w.id]
+ I Schedule $0 $[w.id] Deschedule -$[w.id]
in .fvwm2rc
Read HiddenConsole
AddTo StartFunction
+ I Test (Init) Test (x xterm) StartHiddenConsole
hope this helps
-Dizz
It’s in FAQ entry #7.17 to be precise. Well, not literally, but close enought
And now do I! Many thanks.
np, that was mainly taken from taviso’s config as well, thank him.
