I’m trying to write a weather checking script to put into my fvwmRootMenu. I know I have to use piperead to do it, but I can’t figure it out for the life of me.
The script right now downloads weather info and greps out the temperature and pipes that into its into a weather.txt file. I just need to the Menu to dynamically read the weather.txt file, but I can’t get it to work. Any help would be great. Thanks!
Then you must make sure this script echo’s back FVWM syntax to add these entries to your menu. If the file just contains the elements for the menu entry, then you will need to use PipeRead to do it.
I’m not sure I follow. I guess I don’t understand where else I would need to add the piperead to get the fvwm syntax correct. Could you provide and example maybe? Thanks for the help, by the way.
I gues if you replace date by your script Weather2.sh, it should work (provinding it is in the path, I had strange issue with that, and you may have to put full path to it)[/code]
Zonk. You’re suggestion worked perfectly. Would you mind explaining to me what the \\ are for? I can’t seem to figure out why they make the script work. Thanks.
They’re escaping the command substitution, so that the interpolation doesn’t happen too early; else you’ll get odd results. That way, when the line has ran, it’s the date that’s “echoed” back. Anything else passed to “AddToMenu” before hand is just nonsense until the other operands working on it have done their job.
