I guess this one’s simple, but I couldn’t figure it out.
I have FVWMButtons and gkrellm in the top left corner of my screen. I’d like to raise each one when the mouse pointer enters one of them, and I want the window that had the focus before to be re-focused & raised when the mouse pointer leaves them. For all other windows, I’d like to keep the default ClickToFocus behaviour that I use anyway.
This bit of my .fvwm2rc
Style "*" ClickToFocus
Style "FvwmButtons" Sticky, MouseFocus
Style "*gkrellm*" Sticky, MouseFocus
raises them accordingly, but doesnt give back the focus to the previous window when the pointer leaves them. So I assume that this is a job for FVWM Script, but my attempts failed so far. I guess that someone’s done this before and can just post a small code snippet here?
If you read the Gentoo Forums, you’ll see that I posted almost the exact same message there - sorry, but I didn’t get any feedback there.
I didn’t see your post on the gentoo forums.
Interesting problem. Try using FvwmEvent to catch focus change and leave window events. Then you could call a funciton on focus change to set a variable to store the window id. Keep the previous one as well so you always have the IDs of the last two focussed windows.
On an exit-window event, call a function and check to see which window you left. If it’s FvwmButtons of gkrellm then you can use the previously focussed window id to raise and focus that window.
Needs a little work, but it should be doable
Not a variable – ugh! Use “State” as a means of identifying it. That was you cut out all of the piperead stuff you’d have to do as a result. For example, you could use the “enter_window” and “leave_window” events to dictate what’s what (note: I have not tested this):
DestroyModuleConfig FvwmEvent-foo: *
FvwmEvent-foo: Cmd Function
FvwmEvent-foo: enter_window FE-EnterWindow
FvwmEvent-foo: leave_window FE-LeaveWindow
So the above sets up FvwmEvent (using the alias of ‘FvwmEvent-foo’) to listen on the events specified. Note that you don’t necessarily want to use the event of focus_change as that could cause any number of race conditions. Moving on, the function for FE-EnterWindow might look something like this:
[code]
DestroyFunc FE-EnterWindow
AddToFunc FE-EnterWindow
- I ThisWindow (“gkrellm” AcceptsFocus CurrentPage) Raise
- I TestRc (Match) Any (CurrentPage AcceptsFocus) ThisWindow (“FvwmButtons”) Raise
- I TestRc (NoMatch) Break[/code]
Which for any window called either gkrellm or FvwmButtons Would raise both. So that when you next leave the windows, you might define FE-LeaveWindow as:
DestroyFunc FE-LeaveWindow
AddToFunc FE-LeaveWindow
+ I Prev ( !"gkrellm" !"FvwmButtons" AcceptsFocus) FlipFocus
Or somesuch. It’ll need a bit more work, but it should get you started. The other way of doing it, would be (on focus of either FvwmButtons or gkrellm) would be to set a State on the windows, and test for that state on WindowLeave – it would probably be slightly easier, too.
HTH,
Why piperead? Surely something like this should work?
[code]DestroyFunc FuncRefocus
AddToFunc FuncRefocus
- I SetEnv window_to_be_focussed $[last_but_one_focus]
- I WindowId $[window_to_be_focussed] Focus
- I WindowId $[window_to_be_focussed] Raise
If all you use the focus window event for is to set an environment variable (or state) and you trigger the re-focus on window exit there shouldn’t be any contention.
Or did I miss something obvious?
There might be – it depends on the focus policy you use (i.e. I suspect that ClickToFocus won’t cause many issues, but SloppyFocus might). Either way, passing FvwmEvent something like:
*Foo: Delay 1
Should sort any nasties out.
Many thanks to both of you! This is what it became for now:
*FvwmEvent: leave_window FE-LeaveWindow
+ I TestRc (Match) \
ThisWindow ("gkrellm|FvwmButtons|FvwmPager") \
Prev ( !"gkrellm", !"FvwmButtons", !"FvwmPager", CurrentPage, AcceptsFocus) \
FlipFocus
Lower
It gets confused when I scroll over to a different page and then put the mouse pointer over one of the windows in the list, and to my surprise FvwmEvent seems too slow to catch events when I move the mouse quickly, but otherwise it does exactly what I need.
It seems like the enter_window event doesn’t need to be handled in any special manner because those windows are set to MouseFocus anyway.
