Recently I decided to see how I would fare with assigning random colours to my windows – I use a really simple MWM-decor with a single colour so this worked well for me [1].
In order for this to work I wrote a very simple perl module using perllib which ships with FVWM, and here it is; note that in order to use this you will need to grab Graphics::RGBManipulate from CPAN first:
#!/usr/bin/perl
# Graphics::RGBManipulate comes from CPAN.
use Graphics::RGBManipulate;
use lib `fvwm-perllib dir`;
use FVWM::Module;
use strict;
our( @baseColours, @colourMaps, %colorPairs );
sub _randomPair
my $randomKey = (keys %colorPairs)[rand keys %colorPairs];
return ($randomKey, $colorPairs{ $randomKey } );
my $module = new FVWM::Module(
Mask => M_ADD_WINDOW,
Debug => 0,
$module->addHandler(M_ADD_WINDOW, sub {
my( $self, $event ) = @_;
my $colorsetRef = $colourMaps[ rand @colourMaps ];
my $hilightCS = (split( /\s+/, $colorsetRef->[1]))[1];
my $colorset = (split( /\s+/, $colorsetRef->[0]))[1];
$self->send( "WindowStyle HilightColorset $hilightCS, Colorset $colorset", $event->_win_id );
# We start here -- send all colorsets to FVWM.
foreach( @colourMaps )
foreach my $colorset ( @$_ )
$module->send($colorset);
$module->eventLoop();
$module->showMessage( "Done..." );
BEGIN {
@baseColours = (
"#aaccee",
"#eebbaa",
"#aa99ee",
"#bb99aa",
"#bbdd99",
"#edcd88",
"#ee8844",
"#ee9988",
"#aaeebb",
"#888888",
# key == unfocused. value == focused.
%colorPairs = map {
$_ => lc Graphics::RGBManipulate::tweak( hex => $_, saturation => 0.9 )
} @baseColours;
my $c = 0;
for( 0.. $#baseColours )
my ($focused, $unfocused) = &_randomPair();
my $d = $c++;
push( @colourMaps, [qq|Colorset $d fg black, bg $focused|,
qq|Colorset $c fg black, bg $unfocused|
$c++;
It’s simple – we tell the module to listen out for add_window events and send the windowstyle for that window based on a random sampling of the colours available. You’ll note that I already have a base set of colours to work from – this is deliberate since I wanted to pair colours together. I didn’t want any colours which clashed with one another. Basically, the darker colour is for focus, the lighter is for non-focus; you need to see it for yourselves to get the idea.
If you want to give this a go, I suggest creating a “modules” directory under $FVWM_USERDIR:
mkdir -p ~/.fvwm/modules
Save the above module to whatever name you wish. I called mine FvwmChangeColour.
And then changing your ~/.fvwm/config file such that you do two things:
- You actually tell FVWM about a new module path (preserving the bulitin one with “+” which means append to [2].
ModulePath +:$[FVWM_USERDIR]/modules
- Tell FVWM to load the module.
AddToFunc StartFunction I Module FvwmChangeColour
Here’s a screenshot of course:
edulinux.homeunix.org/~n6tadam/f … olours.png
[1] Contrary to popular belief I do not really use the multicolour-borders patch I wrote some time ago.
[2] This is the only time you should ever need to do anything with ModulePath, incidentally.
