amlug
1
How to restart Fvwm so as not to lose icons in Stalonetray? To log out and load is annoying.
RightTaskBar stalonetray config:
Test (x stalonetray) *RightTbar: (120x24, Swallow(NoClose,UseOld) \
stalonetray 'Exec exec stalonetray --config ~/.fvwm/setup/stalonetrayrc', \
Frame 0, Colorset 21)
This function does the job, but any better solution?
DestroyFunc KillRestart
AddToFunc KillRestart
+ I Exec exec pkill stalonetray
+ I Schedule 500 Restart
Your FvwmButtons config has NoClose
– presumably you should use Kill
here, and have stalonetray
started in StartFunction
Either way, your KillRestart
function is certainly the incorrect thing to do.
amlug
3
Thanks. I took a look at the default Fvwm and it runs with same options (NoClose,UseOld)
. Problem is the InitFunction
I am using at startup.
DestroyFunc InitFunction
AddToFunc InitFunction
+ I Test (Init) Exec nm-applet
+ I Test (Init) Exec volumeicon
Restart works fine with direct exec command at startup.
Exec nm-applet
Exec volumeicon
