Can compile fvwm-cvs with all patches (which doesn’t agree with rox-filer) or zero patches (with no problems with rox-filer) but instant remove some patches but not all it wont compile.
eg. using patches: 01-MenuTranslucency.patch, 07-FluxboxHandles.patch, 08-RoundedCorners.patch
I’ll get error:
[code]In file included from style.c:36:
fvwm.h:275: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘attribute’ before ‘:’ token
fvwm.h:276: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘attribute’ before ‘:’ token
fvwm.h:277: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘attribute’ before ‘:’ token
fvwm.h:278: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘attribute’ before ‘:’ token
style.c: In function ‘style_parse_focus_policy_style’:
style.c:1347: warning: large integer implicitly truncated to unsigned type
style.c:1348: warning: large integer implicitly truncated to unsigned type
style.c:1368: warning: large integer implicitly truncated to unsigned type
style.c:1369: warning: large integer implicitly truncated to unsigned type
style.c: In function ‘style_parse_one_style_option’:
style.c:2486: error: 'struct ’ has no member named ‘has_fluxbox_handles’
style.c:2487: error: 'struct ’ has no member named ‘has_fluxbox_handles’
style.c:2488: error: 'struct ’ has no member named ‘has_fluxbox_handles’
style.c:3426: error: 'struct ’ has no member named ‘has_rounded_corners_top’
style.c:3427: error: 'struct ’ has no member named ‘has_rounded_corners_top’
style.c:3428: error: 'struct ’ has no member named ‘has_rounded_corners_top’
style.c:3429: error: 'struct ’ has no member named ‘has_rounded_corners_bottom’
style.c:3430: error: 'struct ’ has no member named ‘has_rounded_corners_bottom’
style.c:3431: error: 'struct ’ has no member named ‘has_rounded_corners_bottom’
style.c:3435: error: 'struct ’ has no member named ‘has_rounded_corners_top’
style.c:3436: error: 'struct ’ has no member named ‘has_rounded_corners_top’
style.c:3437: error: 'struct ’ has no member named ‘has_rounded_corners_top’
style.c:3441: error: 'struct ’ has no member named ‘has_rounded_corners_bottom’
style.c:3442: error: 'struct ’ has no member named ‘has_rounded_corners_bottom’
style.c:3443: error: 'struct ’ has no member named ‘has_rounded_corners_bottom’
style.c:3569: error: 'struct ’ has no member named ‘has_slightly_rounded_corners’
style.c:3570: error: 'struct ’ has no member named ‘has_slightly_rounded_corners’
style.c:3571: error: 'struct ’ has no member named ‘has_slightly_rounded_corners’
style.c: In function ‘check_window_style_change’:
style.c:4436: error: 'struct ’ has no member named ‘has_rounded_corners_top’
style.c:4437: error: 'struct ’ has no member named ‘has_rounded_corners_bottom’
style.c:4438: error: 'struct ’ has no member named ‘has_slightly_rounded_corners’
style.c:4450: error: ‘struct ’ has no member named ‘has_fluxbox_handles’
In file included from events.c:64:
make[2]: *** [style.o] Error 1
make[2]: *** Waiting for unfinished jobs…
make[2]: *** [events.o] Error 1
In file included from menus.c:43:
menus.c: In function ‘pop_menu_up’:
menus.c:4085: warning: pointer targets in passing argument 5 of ‘FScreenGetScrRect’ differ in signedness
menus.c:4085: warning: pointer targets in passing argument 6 of ‘FScreenGetScrRect’ differ in signedness
menus.c: In function ‘get_menu_options’:
menus.c:8147: warning: pointer targets in passing argument 5 of ‘FScreenGetScrRect’ differ in signedness
menus.c:8147: warning: pointer targets in passing argument 6 of ‘FScreenGetScrRect’ differ in signedness
make[2]: *** [menus.o] Error 1
make[2]: Leaving directory /var/tmp/portage/fvwm-9999/work/fvwm/fvwm' make[1]: *** [all-recursive] Error 1 make[1]: Leaving directory
/var/tmp/portage/fvwm-9999/work/fvwm’
make: *** [all] Error 2
!!! ERROR: x11-wm/fvwm-9999 failed.
Call stack:
ebuild.sh, line 1539: Called dyn_compile
ebuild.sh, line 939: Called src_compile
fvwm-9999.ebuild, line 157: Called die
!!! (no error message)
!!! If you need support, post the topmost build error, and the call stack if relevant.
!!! This ebuild is from an overlay: ‘/usr/local/portage’
[/code]Is there something I’m missing? or forget to do?
