I am trying to write a function that has its options executed one by one, but not simultaneously:
for instance:
- move a window in position A to its previous location B.
- pick a Next window and move it to A
Simply using “+ I” just doesn’t work.
I searched and find “wait”, but it needs a new window name as input parameter.
By the name of “piperead” I guessed the command would take the command stream and execute sequentially. Thus I put 2 command lines in a text file and feed it to Piperead, but it seems to me that the 2 commands get executed at the same time…
Till now I have no idea what else I could try but turn to the forum again for help.
Any pointer or hints would be greatly appreciated.
with kind regards,
Justin
