Set icon position in .fvwm/configure (FVWM2)?
(Apologies if this is a duplicate or the answer is obvious. I’ve searched the man page, forums, and source code without success.)
I like to have the same initial setup each time I start FVWM – applications, their window and icon positions, iconified status, etc.
Correctly-written X11 applications like xterm
support setting all the above:
$ xterm -geometry +800+200 -xrm 'xterm*iconGeometry: +800+600' -iconic
But most “modern” (sigh) programs are missing one or more of the three options, probably because they’re designed to only work with one specific “desktop environment” instead of a window manager, and/or their creators didn’t understand the ICCM, EWMH, and Xt Intrinsics APIs or considered them too antiquated to bother with (despite the fact that their capabilities have never been improved upon). (End editorial comment.)
Such omissions can be mitigated via FVWM’s Style
options of StartIconic
and PositionPlacement
. That’s two out of three, but is there any similar “IconPlacement”, “IconPosition”, etc. for the third?
To clarify, these are desktop icons (no IconBox
), and I don’t need to control the application window’s size as at least all the programs I use either support that via commandline arguments, configuration files, etc. or it’s not applicable to them.
And in case I’m posing an XY problem, should I instead be using a FVWM’s SessionInitFunction
, etc? I’ve shied away from that as it strikes me as more complexity (and opportunites for breakage) than I need, I haven’t found any documentation about whether LightDM works with FVWM for this, and because an explicit/unchanging setup via InitFunction
is actually a better match for my desired workflow.
Thanks for any answers, and (as always) for FVWM.
