Is it possible to set the output of a command to SetEnv. I need to set the output of this command
xprop -id $[w.id] | grep 'WM_NAME(STRING)' | sed -e 's/.*= //'
so when i can it later as $[wm_name]. This will change depending on what window im working on. Ive tried severl this but every time all i get is xprop -id $[w.id] | grep ‘WM_NAME(STRING)’ | sed -e ‘s/.*= //’
Thanks
VoiDeR
