the last days Ive tried out a new config with different Ideas from all the good works here! And this is the (not absolut final) result (but fare away from stable) ; [url=http://www.mitglied.lycos.de/scratchlinux/Screenshots/03-02-2006.png]Slackman
s-Second[/url]
I was impressed by a few Ideas from other users here, impressed from Voiders Pager, Brices mailchecker and also from stonecrest
s FvwmMpd.
I really hope that you`re not angry about that I have stolen your ideas
A few things you cant see on this screenshot, so for example the tray at this moment is "kicker" but I change to xystray the next days. Now I do not need any KDE-Trayicons sinve I
m using FvwmMpd g
A little crazy feature is that the icons from my Menubuttons change to real icons if the mouse points them (really crazy effect, I like to play with it )
O.K., I hope you like it a bit, my Conf has to be cleaned up before I post it, I`ll try to do it the next week.
Special thanks to Voider, Brice and stonecrest for their ideas and work which I have used in my config.
Greetings
Edit:
New Screenshot with new minimal changes
Edit 2 (11-02-06):
Little Change, now Im back to xystray, work
s fine here:)
I think my Config is ready the next three days, sry but it I don`t have enough time yet
Edit:
O.K., heres my config: [url=http://www.mitglied.lycos.de/scratchlinux/Dokumente/Slackman-Stuff.tar.bz2]Slackman
s-Stuff[/url]
(3.8 MB)
I hope you like it
If you have problems or tipps or something else please pn me or write it in this thread.
Before using take a look at the Readme-File in the package and adjust all variables in the config.
I`m using a resulution of 1280x1024 and do not know what happens with other resolutions than mine.
Another Edit: (18-03-2006)
Heres a new Screenshot with little changes in the config, now I
m using 2 instances of conky, one on Desktop and another swallowed in my Topbar. And now Im using a new Deco for Titlebars, take a look :slight_smile: [url=http://www.mitglied.lycos.de/scratchlinux/Screenshots/15-03-06.png]Screenshot-Update[/url] I
ll change the package the next days and try to include a german documentation.
Greetings
