I use SloppyFocus since I can remember, not only in fvwm, and I am done to that behaviour when using the mouse. When using the keyboard binding there is no problem, since I can switch the focus to my convenience.
I have one problem and I have not found a solution to it, though.
I have an urxvt with screen swallowed into a fvwmbuttons panel, which is created outside -far- the screen borders, and slides down when I press win+z, I have a function to do so, and today I rewrote it to make use of State instead of a variable that I used to show/hide it. And in the way, I want to get right of a WarpToWindow command that I use so the window gets the focus and I can type into the terminal emulator. I find it annoying that I have to put my mouse cursor over it to be able to operate in the terminal. Fvwm can give the focus without moving the mouse when using a sloppy focus policy with the rest of the windows.
I think that the problem is that the focus is passed via my function to the FvwmButtons panels, but not to the app inside. But I tried changing it does not work.
The function is this:
DestroyFunc toggle_kuakeitor
AddToFunc toggle_kuakeitor
+ I State 0
+ I ThisWindow (!State 0) All (FvwmKuakeitor) AnimatedMove +$[small_margin]p +0p
+ I ThisWindow (!State 0) All (FvwmKuakeitor) Raise
+ I ThisWindow (!State 0) All (tabbed_URxvt) Focus
+ I ThisWindow (State 0) All (FvwmKuakeitor) AnimatedMove +$[small_margin]p -10000p
And I have no style entry for tabbed_URXvt (the window inside the FvwmKuakeitor panel). The one for the panel is:
Style "FvwmKuakeitor" NoTitle, Sticky, !Iconifiable, FixedSize, \
WindowListSkip, CirculateSkip, State 0, \
Layer 6, Borderwidth 1, HandleWidth 1, !RoundedCorners, RoundedCornersBottom
I can’t see a way to give the focus to the embedded terminal unless I put the pointer into the window (by hand of using WarpToWindow, which works fine). And I was wondering if that is possible at all.
Thanks in advance.
EDIT,
I¡m trying an slightly modified version of the function:
+ I State 31
+ I ThisWindow (!State 31) All (FvwmKuakeitor) AnimatedMove +$[small_margin]p -10000p
+ I TestRc (Match) Break
+ I All (FvwmKuakeitor) AnimatedMove +$[small_margin]p +0p
+ I All (tabbed_URxvt) FlipFocus NoWarp
It has the same problem, though.
I am also experiencing a very weird thing. When I use my key binding the FvwmKuakeitor panel slides down as expected, and if I do it another time it hides. To that point, all is ok.
But there is one glitch: if I have the pointer in the lower part of the screen it works as described above, it works as well if the pointer is close to the left or right edges, where there is a $[small_margin]. But if I have the pointer in the area where the panel appears, I have to press the binding two times to display the panel, and other two times to move it back away.
This is something with the focus as well, I presume, and since is not a very logical thing I think that maybe it is a bug in the SloppyFocus policy, though a weird one. Though it is far more probable that it is a bug in my reasoning
