Updated on 04-22-15.
The config can be downloaded with all required pixmaps in a handy tgz, it’s all original art, so feel free to use it as you please.
[size=85]Wallpaper is not included, copyright and the like…[/size]
The config does not use iconification by default, as I see no reason to do something like that when I have 6 workspaces, but you can send windows to the bottom of the z-order by leftclicking the titlebar.
There is a script which displays mounted volumes on the desktop, you need udevil and devmon to make use of it (or adapt it as needed).
Needless to say, it’s all a bit rough around the edges.
Enjoy
Config files are here (click).
Thanks to Tronar, theBlackDragon, TF and sandwash for their patience and help.
