my second problem I run into and just can’t solve…
I’d like to be able to drag windows between pages (so have page flipping when moving windows), but not when I just get my mousecursor on the screen edge without a window.
How do I solve this, I only find the option to have it always (i.e. with or without a window) or not.
Btw.
SnapAttraction 12
is obsolete. Use[code]#-----------------------------------------------------------------------
SnapAttraction lets nearby windows snap together, or snap to edges so
that they are easier to align on your desktop, The default is off.
Style * SnapAttraction 3 All
[/code]instead. For more info see Style SnapAttraction.
and it works like a charm, but just out of curiosity, why?
Since my EdgeResistance is 10000 there should be no scrolling whatsoever, or is there some special behaviour when I drag windows over the screen edge (obviously there is, as I may conclude)?
The behaviour of dragging windows over the screen edge is handled by options EdgeMoveDelay and EdgeResizeDelay, the first is enabled by default, the second disabled (though disabling EdgeScroll will also affect these options).
