I’ve been running into some small problems with linux/fvwm running on a mac. Not anything to stop this venture, but it’s a pebble in my shoe, for sure.
But I just came into a major problem that would stop me from using a setup like this. On the Macbook air I’m using, the power button is location just above the delete key. Furiously typing caused me to accidentally tap the power button, and linux immediately started shutting down. This is unacceptable to have while coding.
Is there anyway to remap the power key to activate FvwmScript-ConfirmQuit instead of shutting down immediately?
The power key is listed as:
keycode 124 = XF86PowerOff NoSymbol XF86PowerOff
