Does FvwmPager support PNG?
I tired to:
... some config here ...
*FvwmPager: DeskPixmap * /home/a16b03/t.png
Module FvwmPager
And in result i got transparent Pager. Pressing on other page didn’t do anything, but moving app worked.
I tired to:
Module FvwmPager
Yes it does. But you probably meant:
*FvwmPager: DeskPixmap $[HOME]/t.png
Adding $[HOME] to your ImagePath wouldn’t hurt, either. If that still fails, try and XPM.
No, that was test png image, that’s why i wrote full path to it.
BTW is ~/ supported?
Sutpid me, i found problem:
I was suposed to use:
Module FvwmPager 0 5
LOL
No. FVWM doesn’t expand it, hence why I say to use $[HOME], since that’s something FVWM can expand. The only time ‘~/’ works is when you’re at the shell, so “Exec” and PipeRead, effectively.
