I had fvwm 2.5.21 installed for some time; everything was fine
until I upgraded another app called fink, and now fvwm won’t start.
Here is what I have in the fvwm-error file:
dyld: lazy symbol binding failed: Symbol not found: _locale_charset
Referenced from: /sw/bin/fvwm
Expected in: /sw/lib/libiconv.2.dylibdyld: Symbol not found: _locale_charset
There is a libiconv.2.lib in the path /sw/lib but it is a link to a library called
libiconv.2.4.0.dylib, which was created today. So I suppose that the fink upgrade
replaced the libiconv.2.dylib by libiconv.2.4.0.dylib, which is not fvwm compatible.
Can you confirm that in a standard fvwm install, libiconv.2.dylib is not just a link to
libiconv.2.4.0.dylib and what it should be ? Anybody encountered before such a
compatibility issue ? I would appreciate any hint about solving that problem,
thank you in advance.
