i currently have a strange problem with my FvwmPager.
If i do a restart and i am on the first page of my Desktop everything works fine.
but if i do the restart on any other pages my FvwmPager vanishes.
( since i did a WindowListSkip ) on it i have no chance to reach the pager anymore, cause it seems that he is sticky on o other page on the +0+0 ( nordwest corner ) )
before i put the WindowListSkip option on it i coud reach the pager via the WindowList…
Also I would be more inclined to use WindowListSkip directly on the FvwmPager module then on “Desk 0” as it is in your config, but I don’t think it should have anything to do with your issue.
Alright I just tested you config and I’m pretty sure I’ve figured this out.
Your FvwmPager config looks like this:
But it should look like this:
[code]DestroyModuleConfig FvwmPager: *
Pager setup
FvmwPager: Font none FvwmPager: Fore black FvwmPager: Back gray77
#FvwmPager: NoSeparators FvwmPager: Geometry “-0-0” FvwmPager: ShapeLabels FvwmPagerSmallFont "-adobe-helvetica-medium-r---8-------"
no hightlight
#*FvwmPager: NoDeskHighlight
highlight
*FvwmPagerHilight SlateBlue4
*FvwmPagerDeskHilight [/code]
The first line is very important, it should be used everytime you change a module’s config, when not using the “Style” command, that is.
Weird, I tried your config (with my menu’s of course), and after adding that line the pager showed up as normal, whereas otherwise it didn’t even show up on Fvwm start.
i tryed your change and my config on anouther PC of mine
( debian / testing with fvwm 2.5.10 ) same problem
my other laptop is gentoo with 2.5.10
which fvwm version are you using??
hmm i thing ill first try to find a solution ( and ther must be one )
cause fvwm 2.5.12 is not in gentoos portage tree.
and thats why i think there must be a solution: nopaste.easy-coding.de/?id=106
debian std config. tomorrow ill have a look at it. maybe i find the “importand difference” which causes my Pagers misbehaviour.
You could try my config, it works flawlessly with Fvwm 2.512 on Gentoo, and worked before with Fvwm 2.5.10 on both Gentoo and Ubuntu so I’m pretty sure it should work for you too. You can get it at my site in the Downloads section.
And yes Fvwm 2.5.12 is in portage, but it’s masked so you won’t ordinarily be able to install it, put this in /etc/portage/package.keywords (presuming you’re on an x86 architecture pc):
Iirc ShapeLabels can be used to “shape” labels into nearly arbitrary forms by using an image as a mask. It might have been causing problems because it wasn’t used, it was wrongly configured or not configured at all…
Generally it’s a good idea to kick everything you don’t use out of your config when you have problems because it just might be causing problems.
Well, I’m happy you were able to resolve it, now you can start to enjoy Fvwm I would say
