tuner
1
hello,
i have some Problems with minimizig Windows under fvwm.
The big one is: when i minimize one xterm i could not maximize it anymore, and all the other xterms on the same display get stuck.
an other thing is that when i minimize the windows, some are on the top and some on
bottom left corner. can i unify this somehow?
thanks in advance, Toni.
You need to define a binding to do so. For example,
Mouse 1 I A Iconify Off
Will restore a iconified window when clicking over its desktop icon. More on the man page. Search for “bindings” and “context”.
I can’t understand what that means. Please, develop a bit.
Probably your IconBox is too small to hold all your minimized applications. Search the man page for IconBox. The basic syntax is
IconBox left top right bottom
It is just a rectangle where the iconified applications are held. It is defined using a margin on each side, referred to the screen sides.
Regards.
Is this just on iconify? Are you using FvwmAnimate?
Defauls to the whole screen if one hasn’t been defined.
Better to use a geometry, as per:
starshine.org/xteddy/thomas/fvwm … q.html#cf7
tuner
5
Hello,
after a little research i found out, that it’s the problem of WindowShade
Mouse 3 4 A All ($c) WindowShade On
How can i bring the windows up to Maximize again?
thanks, toni.
“$c” doesn’t even make sense. What is it you’re trying to do?
If by that you mean unshade them again, create a binding to a part of a window which does:
WindowShade Off
Or a key-binding, or whatever.
tuner
7
yes,
how can i configure this like a switch.
if it’s minimized and i press the button again do
WindowShade Off
If you want to perform multiple actions in a row you should look into defining a function:
DestroyFunc foo
AddToFunc foo
+ C WindowShade Off
+ C Iconify Off
+ C Raise
+ C Focus
Just an example.
Then you just do
Mouse 1 I A foo
That should unshade, de-iconify, raise and focus a window when you click on its desktop icon.
tuner
9
ok,
but what is, if i want to switch the WindowShade On/Off with the same button.
oops…,
i find it out
it’s when i just remove the On/Off in the end of the text:
Mouse 3 4 A All WindowShade
thanks to all,
(and solved)
