I’m running fvwm2.5.12 under Suse 9.0. In the system.fvwm2rc the Suse Menu is called with an xdg_menu. e.g. + “Menu” Popup sdg_menu .
But in my own .fvwm2rc file this doesn’t work! There is no definition of the xdg_menu in the system.fvwm2rc.
I don’t know what to do…
Has anybody an idea how to get the menu working?
edit: I found it!! Just add this line in the fvwm2rc: PipeRead ‘xdg_menu --charset UTF-8 --format fvwm2’
after this, you can start the menu with Popup xdg_menu
Greetings
Arvodan
–> marked as Solved[/color]
Fixed or solved, doesn’t really matter, I just asked that people would put an indication in the title that indicates that the problem was fixed, but of course it’s nicest if everybody uses the same indication…
