following problem:
I want to switch to another page and the window which is in the foreground should get the focus.
But my function]DestroyFunc FuncGotoPage
AddToFunc FuncGotoPage
- I GotoPage $0 $1
- I ThisWindow (CurrentPage, Raised, !Focused) Focus[/code]doesn’t work
what’s wrong?
Thomas
You’re doing it wrong. I can’t tell if you want something like the following or not:
DestroyModuleConfig FE:*
*FE: new_page foo
*FE: new_desk foo
AddToFunc StartFunction I Module FvwmEvent FE
DestroyFunc Foo
AddToFunc Foo
+ I None (CirculateHit, CurrentPage, Focused) Next (AcceptsFocus) Focus
If this isn’t what you meant, what do you mean?
For example: I am working on a window foo in page 2. Now I want switch to page 3 with e.g the cursor right and the focus should follow to page 3 and the window bla which is raised (fully visible, not overlapped with other windows) should get the focus.
Unfortunately your example doesn’t work as I want - the raised window won’t get the focus.
With[code]
- I None (CirculateHit, CurrentPage, Focused, Raised) Next (AcceptsFocus) Focus
[/code]also
Because the None conditional implies what’s run with the Next command, so you would have to do:
+ I None (CirculateHit, CurrentPage, Focused, Raised) Next (AcceptsFocus, CurrentPage, Raised, ...) Focus
Hi Thomas,
I’ve found the solution]DestroyFunc FuncGotoPage
- I GotoPage $0 $1
- I Next (CurrentPage, !Iconic, !Sticky, !Shaded, !Focused, !Overlapped) Focus[/code]This works in most cases except if windows not overlapping. Then the next matching window in the ring will be focused. But that’s ok (at the moment
Thanks for helping,
Thomas
