I get errors like the following with Fvwm-Crystal:
X Error of failed request: BadValue (integer parameter out of range for operation)
Major opcode of failed request: 113 (X_KillClient)
Value in failed request: 0x800001
Serial number of failed request: 29
Current serial number in output stream: 35
The only thing I know for sure is they append always during a restart, but never at fvwm first startup.
I modified a recipe by commenting out all the module calls into the recipe and its associated files. Also, StartFunction, RestartFunction and InitFunction do nothing - they are cleared. But I still get this error at restart.
The only things left into the recipe are the styles, the preferences loading, the windows decorations and a menu I can get with bindings. Nice and clean 8)
With htop, it is only 2 fvwm threads left, the main one and the one that load the recipe with FvwmCommandS.
It was a long time ago, Thomas tell me to use ThisWindow, but more I read on this, more I am confused. So, how can I debug this issue further? And how can I be sure I need ThisWindow into a statement or don’t need it?
Edit: I commented out further the recipe and ended with the Wallpaper-Set function. It look like ThisWindows is not needed, because I just replaced habak by xlaodimage, and the warning is gone. I am very happy with that because it mean I can begin to move forward. I guess habak is just too old to work fine with current Xorg.
