hello,
i’ve build a script that list all my .desktop files, parse them and make a fvwm menu file.
but i have problem with the command lines of the desktop files.
there are sometimes some strange character like: %u %F
i found the answer here:
standards.freedesktop.org/deskto … c-1.0.html
but i d’ont know how to handle this…
maybe i don’t understand really well…
if someone know about that stuff help would be welcome
This has been done before – search these forums.
You would have to interpolate those yourself in your own parser.
Waste of time if you ask me.
the problem is that i’ve tried 2,3 scripts but they are based on some menu.xml that hide many apps
i just want to have a menu, pretty usable/handable, which list all my apps
sure i’ve not try everything, but i have not seen what i’m looking for and my script is already in an advanced state,
apart those %u %f %x %y problems i didn’t complain
i think i don’t understand what really are those context flag, what does it mean to give an url or files list to an app icon launcher???
for example when i’m under kde i open k menu click on text editor kate and kate just open, there is no context, i believe…, and in my menu kate’s command is something like: kate %u %i %bla %bla…
i’ll lost my nerve with this stupid problem !!!
anyway thanks for the answer
finally i’ve not seen those strange flag under a mime type point of view,
they are usefull in a file manager context.
so i’ve handle them in that sens (replace by blank for most…) and it work pretty good.
stay a problem that many .desktop are apparently made only for a file manager context and handling their command lines
is really a problem at the moment, but it’s another problem
