I Exec /usr/local/libexec/gnome-settings-daemon #–disable-sound
I Exec xmodmap -e “keycode 176 = F13”
I Exec xmodmap -e “keycode 174 = F14”
I Exec xmodmap -e “keycode 140 = F15”
I Exec xmodmap -e “keycode 237 = F16”
I Exec xmodmap -e “keycode 162 = F17”
I Exec xmodmap -e “keycode 178 = F18”
I Exec xmodmap -e “keycode 236 = F19”
I Exec xmodmap -e “keycode 153 = F20”
I Exec xset r rate 250 50
I Exec xset m 3/1 4
I Exec numlockx on
I Exec trayer --edge bottom --align right --widthtype request --transparent true --expand true --alpha 256
I Exec nvidia-settings -l
#+ I Exec pidgin
I Exec $[BROWSER]
I Exec gkrellm[/code]
For some reason these doesn’t work:
key F13 A N Exec echo "volume +1" > /home/killasmurf/.mplayer/pipe
key F14 A N Exec echo "volume -1" > /home/killasmurf/.mplayer/pipe
key F15 A N Exec echo "mute" > /home/killasmurf/.mplayer/pipe
##Media key
#key F16 A N
key F17 A N Exec echo "pause" > /home/killasmurf/.mplayer/pipe
key F18 A N Exec $[BROWSER]
key F19 A N Exec $[EMAILER]
key F20 A N Exec $[TERMINAL]
while this work:
Key I W 4 Module FvwmIdent
Key C A 4 Exec $[CALCULATOR]
key B A 4 Exec $[BROWSER]
Key E A 4 Exec $[EDITOR]
Key F A 4 Exec $[FILER]
Key V A 4 Exec $[VIDEO_PLAYER]
Key P A 4 Exec $[PLAYER]
Note:
MOD4=Super_L in my config, which is win_key
My custom keys on keyboard doesn’t work.
They did work, when i did manual xmodmap in terminal
Also they seam to work if i add them to RestartFunction and restart FVWM
Any ideas where i went wrong?
Edit: Just checked with xev that keys were defined…
Edit2: when i rebind key in FvwmTerm it works fine
I did tried StartFunction as well, it didn’t work…
Actually bough init and startfunction works OK, as i saw in results of xev when i press my keys… they were assigned.
The problem lies in Bindings for some reason.
I just run another simple test:
in FvwmConsole:
read Bindings.conf
and after this all keys worked well as they should
Xnumlock turns on numlock, which i like to use A LOT
I prefer using xmodmap, because then if i break things hard, and just reinstall my system (windows style… sometimes faster than solving problem), i don’t have to care about that file, i just extract backup of my fvwm config and everything works out of the box.
also i have
IgnoreModifiers L25
in my config
P.S. haven’t read your article, will do in next 5 min
Maybe i’m dumb, but i think we’re doing wrong thing here… This problem really doesn’t seam to be xmodmap related…
is .xinitrc used when i use gdm to start fvwm session?
P.S. i did read that topic, in case you wonder… maybe i didn’t understand something
EDIT:
i just checked .xsession-errors
[fvwm][ParseBinding]: <<ERROR>> No such key: F13
[fvwm][ParseBinding]: <<ERROR>> No such key: F14
[fvwm][ParseBinding]: <<ERROR>> No such key: F15
[fvwm][ParseBinding]: <<ERROR>> No such key: F17
[fvwm][ParseBinding]: <<ERROR>> No such key: F18
[fvwm][ParseBinding]: <<ERROR>> No such key: F19
[fvwm][ParseBinding]: <<ERROR>> No such key: F20
