I use the file C:\cygwin\usr\X11R6\bin\startxwin.bat to start a xterm. I have used you file to change my own and it now looks like this:
@echo off
SET DISPLAY=127.0.0.1:0.0
REM
REM The path in the CYGWIN_ROOT environment variable assignment assume
REM that Cygwin is installed in a directory called 'cygwin' in the root
REM directory of the current drive. You will only need to modify
REM CYGWIN_ROOT if you have installed Cygwin in another directory. For
REM example, if you installed Cygwin in \foo\bar\baz\cygwin, you will need
REM to change \cygwin to \foo\bar\baz\cygwin.
REM
REM This batch file will almost always be run from the same drive (and
REM directory) as the drive that contains Cygwin/X, therefore you will
REM not need to add a drive letter to CYGWIN_ROOT. For example, you do
REM not need to change \cygwin to c:\cygwin if you are running this
REM batch file from the C drive.
REM
SET CYGWIN_ROOT=\cygwin
SET PATH=.;%CYGWIN_ROOT%\bin;%CYGWIN_ROOT%\usr\X11R6\bin;%CYGWIN_ROOT%\usr\X11R6\lib;%CYGWIN_ROOT%\lib%PATH%
SET XAPPLRESDIR=/usr/X11R6/lib/X11/app-defaults
SET XCMSDB=/usr/X11R6/lib/X11/Xcms.txt
SET XKEYSYMDB=/usr/X11R6/lib/X11/XKeysymDB
SET XNLSPATH=/usr/X11R6/lib/X11/locale
REM
REM Cleanup after last run.
REM
if not exist %CYGWIN_ROOT%\tmp\.X11-unix\X0 goto CLEANUP-FINISH
attrib -s %CYGWIN_ROOT%\tmp\.X11-unix\X0
del %CYGWIN_ROOT%\tmp\.X11-unix\X0
:CLEANUP-FINISH
if exist %CYGWIN_ROOT%\tmp\.X11-unix rmdir %CYGWIN_ROOT%\tmp\.X11-unix
REM
REM The error "Fatal server error: could not open default font 'fixed'" is
REM caused by using a DOS mode mount for the mount that the Cygwin/X
REM fonts are accessed through. See the Cygwin/X FAQ for more
REM information:
REM http://x.cygwin.com/docs/faq/cygwin-x-faq.html#q-error-font-eof
REM
if "%OS%" == "Windows_NT" goto OS_NT
REM Windows 95/98/Me
echo startxwin.bat - Starting on Windows 95/98/Me
goto STARTUP
:OS_NT
REM Windows NT/2000/XP/2003
echo startxwin.bat - Starting on Windows NT/2000/XP/2003
:STARTUP
REM Brief descriptions of XWin-specific options:
REM
REM -screen scr_num [width height]
REM Enable screen scr_num and optionally specify a width and
REM height for that screen.
REM Most importantly, any parameters specified before the first -screen
REM parameter apply to all screens. Any options after the first -screen
REM parameter apply only to the screen that precedes the parameter.
REM Example:
REM XWin -fullscreen -screen 0 -screen 1 -depth 8 -screen 2
REM All screens will be fullscreen, but screen 2 will be depth 8, while
REM screens 0 and 1 will be the default depth (whatever depth Windows
REM is currently running at).
REM -multiwindow
REM Start an integrated Windows-based window manager. Not to be used
REM with -rootless nor -fullscreen.
REM -rootless
REM Use a transparent root window with an external window manager
REM (such as twm). Not to be used with -multiwindow nor
REM with -fullscreen.
REM -fullscreen
REM Use a window as large as possible on the primary monitor.
REM -multiplemonitors
REM Create a root window that covers all monitors on a
REM system with multiple monitors.
REM -clipboard
REM Enable the integrated version of xwinclip. Do not use in
REM conjunction with the xwinclip program.
REM -depth bits_per_pixel
REM Specify the screen depth to run at (in bits per pixel) using a
REM DirectDraw-based engine in conjunction with the -fullscreen
REM option, ignored if the -fullscreen option is not specified.
REM By default, you will be using a DirectDraw based engine on any
REM system that supports it.
REM -unixkill
REM Trap Ctrl+Alt+Backspace as a server shutdown key combination.
REM -nounixkill
REM Disable Ctrl+Alt+Backspace as a server shutdown key combination (default).
REM Example:
REM XWin -unixkill -screen 0 -screen 1 -screen 2 -nounixkill
REM Screens 0 and 1 will allow Ctrl+Alt+Backspace, but screen 2 will not.
REM -winkill
REM Trap Alt+F4 as a server shutdown key combination (default).
REM -nowinkill
REM Disable Alt+F4 as a server shutdown key combination.
REM -scrollbars
REM Enable resizing of the server display window. Do not use in conjunction
REM with -multiwindow nor with -rootless.
REM -nodecoration
REM Draw the server root window without a title bar or border.
REM Do not use with -mutliwindow nor with -rootless.
REM -lesspointer
REM Hide the Windows mouse cursor anytime it is over any part of the
REM window, even if Cygwin/X is not the window with the focus.
REM -refresh rate_in_Hz
REM Specify a refresh rate to use when used with the -fullscreen option.
REM -trayicon
REM Enable the tray icon (default).
REM -notrayicon
REM Disable the tray icon.
REM Example:
REM XWin -notrayicon -screen 0 -screen 1 -screen 2 -trayicon
REM Screens 0 and 1 will not have tray icons, but screen 2 will.
REM -emulate3buttons [timeout]
REM Emulate 3 button mouse with an optional timeout in milliseconds.
REM -xf86config
REM Specify an XF86Config-style configuration file.
REM -keyboard
REM Specify a keyboard device from the configuration file.
REM
REM Startup the programs
REM
REM Startup the X Server with the integrated Windows-based window manager.
REM WARNING: Do not use 'xwinclip' in conjunction with the ``-clipboard''
REM command-line parameter for XWin. Doing so would start two clipboard
REM managers, which is never supposed to happen.
run XWin -multiwindow -clipboard -silent-dup-error
REM Startup an xterm, using bash as the shell.
run xterm -e /usr/bin/bash -l
REM
REM Startup the twm window manager.
REM WARNING: Do not use an external window manager in conjunction with
REM the ``-multiwindow'' command-line parameter for XWin. Doing so
REM would start two window managers, which is never supposed to happen.
REM
REM run fvwm2
REM Set a background color. Only needed when not using -multwindow for XWin.
REM run xsetroot -solid aquamarine4
in my homedir I have the following files:
.xinitrx
#exec fvwm2 -f /usr/X11R6/share/fvwm/system.fvwm2rc-sample-95
#exec fvwm2
exec fvwm2
#exec openbox
#ssh-agent wmaker > ~/.ssh-agent
#export DISPLAY=localhost:0
#xhost +
.xserverrc
exec X :0 -clipboard
.Xresources
XTerm.VT100.font: -*-lucidatypewriter-medium-*-*-*-14-*-*-*-*-*-*-*
XTerm.VT100.boldFont: -*-lucidatypewriter-bold-*-*-*-14-*-*-*-*-*-*-*
XTerm.VT100.scrollBar: True
XTerm.VT100.visualBell: True
XTerm.VT100.loginShell: True
XTerm.VT100.background: Black
XTerm.VT100.foreground: White
I am not sure if all are necessary. But when I run startxwin.bat and type “startx” I get this error:
mos@mos-5a13658e594 /home
$ startx
Welcome to the XWin X Server
Vendor: The Cygwin/X Project
Release: 6.8.2.0-4
Contact: mailto:cygwin-xfree@cygwin.com
XWin was started with the following command line:
X :0 -clipboard
_XSERVTransmkdir: Owner of /tmp/.X11-unix should be set to root
winValidateArgs - g_iNumScreens: 1 iMaxConsecutiveScreen: 1
winCheckDisplayNumber - Cygwin/X is already running on display 0
Fatal server error:
InitOutput - Duplicate invocation on display number: 0. Exiting.
winDeinitMultiWindowWM - Noting shutdown in progress
giving up.
xinit: Connection reset by peer (errno 104): unable to connect to X server
xinit: No such process (errno 3): Server error.
Hope someone hs any ideas!
