At the moment, I’m just starting out trying to get fvwm the way I like it (only started it using it yesterday). I’m trying to track down where FvwmButtons is started. I’ve found the .fvwm2rc file (arch linux here) and found this pointer to the file:
# $F/.start-apps-man $F/.start-FvwmButtons $F/.start-DeskerPanelButtons \
which is commented out - even then - the file .start-FvwmButtons says this:
# No Buttons Bar
But I’m getting these buttons on my screen
http://i.imgur.com/NFpdZLV.png
How do I find where the FvwmButtons is being enabled and switch this off?
Tia
Adam
