I have a problem with FVWM, the module FvwmIconMan and keybinding will not be in effect, then I press the hotkey which I defined in my configuration, nothing happened. I restart, the keybinding and FvwmIconMan don’t work.
Your question is very vague. Share some details, what keybinding is not working, what do you expect it to do, what is the config you used to make this keybinding.
Same thing with FvwmIconMan. What config are you using, what is not working about FvwmIconMan?
