ImagePath ${HOME}/.fvwm/images
Key Space A 4 Popup Menu_Main
Colorset 0 fg white, bg black
Colorset 1 fg black, bg #FA0000
MenuStyle * Font "xft:Bitstream Vera Sans Mono:style=Roman:size=12"
MenuStyle * TrianglesSolid
MenuStyle * HilightBack
MenuStyle * MenuColorset 0
MenuStyle * ActiveColorset 1
MenuStyle * ItemFormat "%5.5i%|%5.5l%5.2>%|"
DestroyMenu Menu_Main
AddToMenu Menu_Main
+ %music.note-24x24.png%"&This" Popup Menu_This
+ "T&hat" Popup Menu_That
+ "The &Other" Popup Menu_TheOther
The above code along with a transparent icon, causes the icon to get brighter when selected. It goes darker when not selected. Is there a way to stop this, either constant brighter/darker?
Does this happen with other images? I couldn’t reproduce this using one of my transparent images, though not quite sure why the image would react to the color changing close to it.
Sorry, I missed the icon. I added your config to mine and made two icons. One transparent and another black background to check if its the icon.
There is no icon flicker. ActiveColorset doesn’t affect it.
No, not at all. That’s not the point I was making.
You have a question which others are trying to help you with, that’s different.
I appreciate that fvwm isn’t easy, and it does often take more effort than other WMs out there. Not everyone has the time to devote to that – so if that’s how you feel, that’s fair enough.
