In my current config i’ve got two autohided panels. Wallpaper changer is swallowed inside one of them. After I change the wallpaper the other panel width is change to 1. Everything is work fine if the autohide is switched off.
[code]juuzer@user ~ $ fvwm -version
fvwm 2.7.0 compiled on Apr 19 2011 at 09:23:29
with support for: ReadLine, XPM, PNG, SVG, Shape, XShm, SM, Xinerama, XRender, XCursor, XFT, NLS
fvwm comes with NO WARRANTY, to the extent permitted by law. You may
redistribute copies of fvwm under the terms of the GNU General Public License.
For more information about these matters, see the file named COPYING.
