I’d like to disable the clock in the taskbar. I haven’t found anything in the manpage about disabeling it.
The Taskbar leaves an annoying little space at the bottom right corner (about 5 pixels or so)
And then I’d like to leave some space at the bottom left corner for xmms. I have experimented with Geometry for a while now but whatever I do, the Taskbar takes the full width of the screen (apart from the 5 pixels mentioned above)
What i want to have looks somewhat like this:
Beginning of screen|[—Here is XMMS—][—Taskbar stretched till the end of screen —]|End of screen
Well, I thought I answered your post, apparently I didn’t, sorry
But FvwmTaskBar really isn’t a very powerful module and it’s got quite a load of annoying quirks.
I used another module to reach the same result, I’m not entirely sure but I think it was FvwmIconMan which I configured to look like a pager. I don’t have that old config on this machine, but if you can’t figure it out I’ll try to find it for you
Could you please help me with this? First of all, I don’t know anything about swallowing and second I don’t get any satisfaciory results here. If I open enough windows the buttons move off the screen. They should have a variable widht and shrink if more windows are opened than it could normaly display… just like the taskbar does.
I made a little picture how it should look like in the end.
I apologise for such a long delay, but either you’ve been waiting a long time, or you’ve figured it out by now. As an example of swallowing FvwmIconman inside FvwmButtons, take a look at the following screenshot:
