Is it possible to make a taskbar that holds a little reference to each minimized window instead of the small icon that get created now?
It should also stay on top.
Look at “FvwmIconMan” – if you search the forums for that, you’ll find lots on it. As to making it StayOnTop:
Style FvwmIconMan Layer 0 10
The “10” is excessive, but it does make sure it will always be so.
I don’t understand what you mean by the “small icon”. Do you mean the icon that you can see when an application is minimised? If so, what I do when using FvwmIconMan is to use the style:
Style ** NoIcon
So that I don’t see any icons.
– Thomas Adam.
