Hallo, wenn ich ein Server, SUSE 10.3, opensuse11.2 oder SLES11 sp1 mit fvwm2 installiert, mit Teamviewer über Internet verbinden, kann ich das Shell Fenster nicht vergrößern oder verkleinen. Ich kann gar nichts mehr machen, bis Kunden auf seinen Maus bestätigen. Kunde kann das Shell Fenster große verändern, ohne Problem. Ich kann, per Teamviewer, das Fenster verschieben, zu machen und neue aufmachen. Hat jemand eine Idee?
Sorry, as am American Ishould have know better. I have a Server with any one of the following OS, SUSE 10.3, opensuse11.2 or SLES11 sp1 with fvwm2 and Teamviewer installed. When I start Teamviewer over the Internet, I can’t adjust the size of the Shell window. When I klick on the edge of the window my window freezes and I can’t do anything until the customer klicks on his maus. Then my window funktions again. The customer can adjust the size without any problems. I can change the position of the windows anywhere I want. Does anybody have an idea?
My company won’t let me do that. Sofar it is not a big problem. Everything else works, I just can’t resize the shell window. As it works fine from the console just not with teamviewer. I think it has something to do with the way teamviewer grabs the mouse. But since I’m new to teamviewer I quest I’ll just keep tring different settings.
Szenario 1: connect from other system to my system (unfortunately over LAN only - not over internet)
Other system with Gnome 2.6 and Teamviewer 6
My system with Fvwm 2.6.6 and Teamviewer 6
Result:
Can resize host window and windows on guest side
Szenario 2: connect from my system to other system
Result:
Strange … After connecting to the other system it logs out after 1 or 2 seconds and goes back to login screen.
Tomorrow I am at a friend of mine and he has an OpenSuse 11.2. Then I will check it again. Perhaps it is a problem of the very old LinuxMint 8 on my other system.
