from the man pageItemDraw: Display an icon and/or a string.
so i wroteChangeIcon 1 $icon
ChangeTitle 1 $title
but appears only the icon… why?
thanks in advance!
I assume (thanks to the distinct lack of detail) you’re using FvwmScript here – in which case you can start by posting the full script in its entirety.
well i think the problem is not that it isn’t possible but more that FvwmScript hasn’t an option how to arrange the title and icon at the same time
Look :
http://img160.imageshack.us/img160/7056/fvwmscript0xn.jpg
and the relevant part of the config
Widget 1
Property
Type ItemDraw
Size 156 150
Icon mpd/play.png
Position 3 3
Flags NoFocus NoReliefString Left
Main
Case message of
SingleClic:
Begin
Quit
End
End
the flags left, center and right just change the horizontal orientation of the text !?
any ideas someone ??
Yes, horizontal. Again (and like the previous poster) what is it you’re trying to do?
maybe to have the icon on the left side or on the right side of the text ??
the think what he was planning to do (and i tried also ) to have an widget with a icon and text at the same time. in my example it’s an 16x16-icon and only when i have a widget greater then 100x100 the text is also show ( that’s why he says he only sees the icon) …
the thing is you might want to have for any reason text and an icon on the same and the man page says it works ?!
this is the script: to make it work i use 2 widgets but i know that i can use only one with icon and title in the same widget; it works only with gmail but in the future i’ll add others[code]WindowTitle {mails}
WindowSize 80 16
Font “xft:Andale Mono:size=8”
Colorset 10
Init
Begin
Do {Exec fetchmail -c > $[fvwm_scripts]/tmp}
Set $news = (GetOutput {exec cut -d" " -f2 /home/sazzu/.fvwm/sazzus03/scripts/tmp} 1 -1)
If $news=={No} Then
Begin
Set $title = { 0 msg}
ChangeTitle 2 $title
End
Else
Begin
If $news==null Then
Begin
End
Else
Begin
Set $number = (GetOutput {exec cut -d" " -f1 /home/sazzu/.fvwm/sazzus03/scripts/tmp} 1 -1)
Set $title = { }$number{ gmail}
End
End
End
PeriodicTasks
Begin
If (RemainderOfDiv (GetTime) 120)==0 Then
Begin
If $news=={No} Then
Begin
End
Else
Begin
If $news==null Then
Begin
End
Else
Begin
End
End
End
End
Widget 1
Property
Type ItemDraw
Size 30 16
Position 4 2
Icon mail/16.png
Flags NoFocus Right NoReliefString
Main
Case message of
SingleClic :
Begin
End
End
Widget 2
Property
Type ItemDraw
Size 50 16
Position 30 0
Flags NoFocus Left NoReliefString
Main
Case message of
SingleClic :
Begin
End
End[/code]
