I currently have a function to toggle a window maximized and remove the handles and border.
AddToFunc ToggleMaximized
+ C ThisWindow (!Maximized) WindowStyle HandleWidth 0
+ C ThisWindow (!Maximized) RecaptureWindow
+ C Maximize
+ C ThisWindow (!Maximized) WindowStyle HandleWidth 7
It is a bit naff and uses the deprecated RecaptureWindow function. Without it when it maximizes and removes the border, there is a gap left between the window and the screen edge where the border would have taken up.
Ah brilliant. Thank you. That will likely be more robust.
EPEL only has Fvwm 2.6.6 but I will have an attempt compiling from source. Most importantly, if Recapture* ever does get removed, I can use the Maximize Fullscreen as a replacement.
Its getting there, though I have noticed that programs such as Firefox or Gimp remember the size so when they start, they start the same size of their maximized state but are infact not maximized.
I have a hack to set the max windows size to 90% and then on resize (and maximize) bump it back to 100%.
Again pretty naff but I am not sure there is another way.
I guess ideally windows that were closed whilst they were maximized should start up again maximized (I assume there is some window system standard for this?)
