2.5.15 contains changes that makes the translucency patch for 2.5.14 to work bad. I’ve updated the translucency patch to work with the new MouseWheel ScrollsMenu* menu styles. dd.chalmers.se/~griph/fvwm-2 … cy.diff.gz
I found some errors in the patch when testing it against the released 2.5.15. A fixed patch is here:
Hi Gramphos,
I’ve applied this to 2.5.16 and so far translucency is working fine (although I’ve not tried the scrollsmenu thing).
Thanks very much!
Rob
It\s working again now. I did something wrong when testing .htacess restrictions on another file. (The recently changed from Apache to roxen as webserver, and they use differnet .htaccess formats)
