Not sure this is the right sub forum.
Anyway, I am trying to make a transparent .xpm for a dock. I can’t figure out how to do this in the Gimp.
You can’t have transparent XPMs - use a PNG.
Sorry – this needs clarifying. You can have transparency, but not reliably. You can set ‘#transparent’ (or indeed ‘none’) for colour options, but you’re better off using a PNG.
