That is way to overkill to my level. I just want a single button that when pressed opens a menu with some other buttons. Hopefully that is not so complicated?
Right. Well, what you’re describing there is not a panel. A panel in FvwmButtons terminology is a button that swallows up an FvwmButtons instance, and hides it, until you press it again.
If you just want to use FvwmButtons like a “menu” system, then see this post:
I’d better upload a new and improved version then, the one currently online is still quit quircky, but I didn’t upload a new one because I was busy with the Emacs fvwm-mode…
