I have written a short fvwmperl module to use Tracker::Scheduler. To show that the Scheduler works in the simplest way before I try to use it in other places. But it isn’t working, which means I’ve done something wrong.
Basically, when I start the module, “Starting…” shows up in ~/xsession_errors. But if my schedule command worked properly, then “Stopping…” would show up 2 seconds later. But it never does.
So, what am I doing wrong please? Using version 2.6.5 on Debian testing. Thanx.
[code]
#!/usr/bin/perl
use strict ;
use warnings ;
use lib fvwm-perllib dir;
use FVWM::Module ;
use FVWM::Tracker ;
use FVWM::Tracker::Scheduler ;
my $module = new FVWM::Module(
Name => ‘Notify’,
Debug => 0,
[Notify]: Starting...
[Notify]: Stopping...
Btw. you don’t need FVWM::Tracker and FVWM::Tracker::Scheduler because it’s a subclass of FVWM::Module.
With this
#!/usr/bin/perl
use strict ;
use warnings ;
use lib `fvwm-perllib dir`;
use FVWM::Module ;
Name => 'Notify',
Debug => 2,
my $scheduler = $module->track('Scheduler') ;
$module->debug("Starting...", 0) ;
$scheduler->schedule(2, sub {
$module->debug("Stopping...", 0) ;
$module->terminate ;
$module->event_loop ;[/code]
you get the following output][Notify]: sent [SET_MASK 0]
[Notify]: sent [SET_SYNC_MASK 0]
[Notify]: sent [Schedule 2000 8097956 SendToModule Notify FVWM::Tracker::Scheduler alarm 1]
[Notify]: sent [NOP FINISHED STARTUP]
[Notify]: sent [SET_MASK 4194304]
[Notify]: got M_STRING [FVWM::Tracker::Scheduler alarm 1]
[Notify]: Stopping...[/code]
Have you put the module into /usr/lib/fvwm/2.6.5?
You can add a local module path to your config with [code]
ModulePath $[FVWM_USERDIR]/lib:+
Now make a folder lib under ~/.fvwm and copy the module into it. Restart FVWM and you have it. 8)
I have the module in ~/.fvwm/modules, but that folder is in the modulepath. I also have other modules in that folder that are working fine.
You amended my module. So I copied it exactly into a new file, chmod 755, and then started it via FvwmConsole, with xsession-errors output as below. I also added in a divider line to the output. And the lines below the divider show debug output after I stopped the module at 20 seconds - KillModule notify.pl.
I know the Schedule commands in my ~/.fvwm/config work fine. But appears my fvwm is not behaving as expected. Correct?
[code][Notify]: sent [SET_MASK 0]
[Notify]: Starting…
[Notify]: sent [Schedule 2000 8766028 SendToModule Notify FVWM::Tracker::Scheduler alarm 1]
[Notify]: sent [Deschedule 8766028]
[Notify]: Failed send [Deschedule 8766028]
[Notify]: sent [Nop] FINISH[/code]
