Hello everyone!
I’m glad to finally posting in this great forum.
I use a fvwmbuttons to display some icons and laptop informations.
I use two fvwmscripts to show my battery level and my cpu temperature (with powersave)
and I swallow it in my fvwmbuttons.
It would have helped if you posted your FvwmButtons config. There could be any number of reasons why your FvwmScript isn’t being swallowed, although typically it’s because:
You got the hangon incorrect.
The script loads before FvwmButtons does (if you’re not spawning it from FvwmButtons).
Your screenshot is useless. Post your FvwmButtons config somewhere along with your FvwmScripts.
The reason why your second script fails (FvwmApplet-Temp) is because you’re setting the title to FvwmScript-Battery which has already been swallowed, and of course is not the expected hangon of FvwmScript-Temp which you so rightly have in your FvwmButtons config, hence in FvwmApplet-Temp change:
