Update cross references?
Would it be possible for someone with access to the data base for the forum to do a global change that updates cross-references among posts? It’s a minor point, but it seems like it might be an easy fix. I’d imagine that references to the wiki (though not to particular wiki pages) should also be easily fixable.
I’ve already done this. If you spot places which I’ve missed, do say.
If you look at theBlackDragon’s Forum Guidlines the links to the Wiki and the Forum go to the old locations.
That’s different from what you were originally asking.
Fixed anyway. Thanks.
I had originally seen a bad cross reference–a link from one post to another that didn’t work because it went to the old forum. I can’t find it now though. Will let you know if I run into anything of the sort again.
