I wrote a very simple function to keep some of my windows in the top layer:
# Function: ToggleAlwaysOnTop
# Toggle always on top.
DestroyFunc ToggleStaysOnTop
AddToFunc ToggleStaysOnTop
+ I ThisWindow (Layer 6) WindowStyle StaysPut
+ I ThisWindow (Layer 4) WindowStyle StaysOnTop
+ I UpdateStyles
+ I Raise
This function seems to do the job. The problem is that I also have a button decoration on my windows, which depends on whether the window is on the top layer. This decoration is defined as:
+ AddButtonStyle 6 (Vector 4 50x25@1 75x75@0 25x75@0 50x25@1)
+ ButtonStyle 6 - MwmDecorLayer 6
When I trigger ToggleStaysOnTop
by clicking this button, the decoration correctly changes shape, but when I call the function from a keyboard binding the decoration does not change. It changes correctly only when I unfocus the window, or do any other action that may modify the other styles of the window, like making it sticky.
From this I concluded that there must be a function to update the decorations from within my ToggleStaysOnTop
function, but I could not find anything. Is there any such function? If not, is there any other method that would allow me to achieve this?
Thank you in advance.
FVWM version:
fvwm3 1.0.2 (released)
with support for: PNG, Shape, XShm, SM, XRandR, XRender, XFT, NLS
