Even with a maximized window on each monitor, my mouse slips right over into the other monitor without any delay. I don’t see very well, so I have trouble finding the mouse cursor easily. The two monitors are not side by side.
Can you recommend any way to fix this?
There’s no edge resistance for the pointer itself, unless moving a window between monitors.
One thing you could do is maybe have something which indicates where the cursor is:
@FreedomRocks, a new feature CursorBarrier
was added to fvwm3 (you can find it in the main branch on github) that allows you to create barriers to keep your mouse from moving across monitor boundaries. You could set up a CursorBarrier
on each monitor to prevent the mouse from moving from one monitor to another, and then use WarpToWindow
on the root window to move the cursor between monitors. The new option is documented in the manual page.
Note, You will need to install the development libraries for the XFixes extension and build fvwm3 with meson to use this feature.
Late to the party… been a user for ages, but just transitioning to Fvwm3 for easier use of multiple monitors, have the same problem:
Quick n’ dirty solution to “lost” cursor that needs no added software is clicking any mouse button associated with a pop-up menu (all of them?).
MUCH larger menu than mouse-pointer catches the eye. Cursor will be right there, with it.
FWIW I also use the “Redglass” cursor family..
