While looking for an explaination of how to get my windows key to be used for key bindings, I can across this post]http://www.fvwmforums.org/phpBB3/viewtopic.php?f=33&t=1796#p10119[/url]
In it, is says:
But I can’'t find any code to show how to use more than one key for key binds (aside from modifiers)
How can I use Super_L and Tab as a key binding?
Ok, looks like I found the answer in the ArchWiki]FVWM - ArchWiki
So I’m looking to use:
Silent Tab A 4 Exec exec $[infostore.program]
The confusion came from one example using Super_R as the key and not as the modifier. Appearently it can be used as both.
Ty ArchWiki for pointing this out.
