My display is 1920 pixels wide, but the viewport I’m getting on one of my machines is too wide by 1024, so 2944 instead of 1920. I had noticed this because if I move the mouse to the right it disappears into the phantom part of the viewport. Now I’m trying to create a centered button bar and it’s showing up 512 pixels too far to the right. (I confirmed that $[vp.width] is 2944.)
You wrote “machines”. I guess you connected them remote via … ?
In general you could calculate the button bar position depending on $[vp.width]]
PipeRead ‘echo InfoStoreAdd bbar_geometry x+$(($[vp.width]/2-/2))+<your-bbar-y-pos’
Add the infostore variable to your FvwmButtons configuration]
DestroyModuleConfig YourButtonBar: *
*YourButtonBar: Geometry $[infostore.bbar_geometry][/code]
Remember: infostore is available since FVWM 2.6.3 I guess. For older FVWM versions use SetEnv instead.
I’m using the machines directly on the console—several different machines with the same .fvwm2rc file. The problem I am describing is limited (I believe) to only one of four machine. (Manifestation is kind of subtle if you aren’t computing something from $[vp.width], so it’s possible I overlooked it.)
Yeah, in general it seems like I could calculate the button position using $[vp.width] except that $[vp.width] is 2944 and the actual screen width is 1920. So the button comes out in the wrong place, 512 pixels too far to the right.
It appears that the problem is with xrandr, which has mysteriously decided to give me extra width in my display. I’m not sure why, but it’s not an fvwm issue.
At the moment, xorg.conf doesn’t exist. (At least I can’t find one.) I got the impression xrandr was supposed to eliminate the need for this file. The cause of the problem seems to be that xrandr thinks I have a DVI and a VGA signal and it’s making the virtual screen big enough for both to coexist. I’m not sure why xrandr thinks that, since only one cable (dvi) is connected, and there isn’t even a VGA out on this computer. But there you have it. If I select the correct size with xrandr and restart fvwm then everything works as desired.
Per default Xorg determine its settings depending on your hardware and /usr/share/X11/xorg.conf.d/. So xorg.conf isn’t needed at all. But sometimes it helps to create a default xorg.conf with
sudo Xorg -configure
and then editing the parts you have to change for proper work.
Would you post the output of
xrandr -q
If the hardware/driver shows a VGA (could be internal only) xrandr displays it. Normally xrandr doesn’t change anything unless you do it wit this tool. Check the Xorg.log and the scripts in /usr/share/X11/xorg.conf.d/. Perhaps this configuration will be set from a xorg script … who knows
My configuration is the default I got when I installed ubuntu.
The initial status from xrandr is:
Screen 0: minimum 320 x 200, current 2944 x 1200, maximum 8192 x 8192
DVI-I-1 connected primary 1920x1200+0+0 (normal left inverted right x axis y axis) 582mm x 364mm
1920x1200 59.95*+
1600x1200 60.00
1280x1024 75.02 60.02
1152x864 75.00
1024x768 75.08 60.00
800x600 75.00 60.32
640x480 75.00 60.00
720x400 70.08
DP-1 disconnected (normal left inverted right x axis y axis)
DP-2 disconnected (normal left inverted right x axis y axis)
VGA-1-1 connected 1024x768+1920+0 0mm x 0mm
1024x768 60.00*
800x600 60.32 56.25
848x480 60.00
640x480 59.94
1024x768 (0x43) 65.000MHz
h: width 1024 start 1048 end 1184 total 1344 skew 0 clock 48.36KHz
v: height 768 start 771 end 777 total 806 clock 60.00Hz
800x600 (0x44) 40.000MHz
h: width 800 start 840 end 968 total 1056 skew 0 clock 37.88KHz
v: height 600 start 601 end 605 total 628 clock 60.32Hz
When I change the virtual display size I get this, where it complains about lacking space for the VGA:
feynman> xrandr --fb 1920x1200
xrandr: specified screen 1920x1200 not large enough for output VGA-1-1 (1024x768+1920+0)
X Error of failed request: BadValue (integer parameter out of range for operation)
Major opcode of failed request: 140 (RANDR)
Minor opcode of failed request: 21 (RRSetCrtcConfig)
Value in failed request: 0x780
Serial number of failed request: 40
Current serial number in output stream: 40
Afterwords it looks like this:
Screen 0: minimum 320 x 200, current 1920 x 1200, maximum 8192 x 8192
1920x1200 59.95*+
1600x1200 60.00
1152x864 75.00
800x600 75.00 60.32
640x480 75.00 60.00
720x400 70.08
VGA-1-1 connected
1024x768 60.00
800x600 60.32 56.25
848x480 60.00
640x480 59.94
Looks like your system is configured in Xinerama mode.
Have you
Xinerama on
in your .fvwmrc? If so disable it with
Xinerama off
Yeah, it does what the manpage says:
Ok, now VGA-1-1 is connected but off. You could also do this without error message]
xrandr --output VGA-1-1 --off; xrandr --output DVI-I-1 --auto
[/code](Probably only the --off part is enough).
I found that running your command to disable VGA worked. However, I had trouble finding a way to run it. If I run it from fvwm, it’s too late. Then fvwm needs to be restarted afterwards.
I tried to get lightdm to run it but after messing around for a while with its config file I still couldn’t get this working. (lightdm wasn’t running my script at all) I was about to try writing an xorg.conf but then I got the idea of installing the nvidia binary driver. Installing this driver fixed the problem. So there’s a workaround, of sorts.
