Hi folks,
may I proudly present to you my third fvwm-configuration (and the one I feel most comfortable with):
Big Screenshot
The Configuration (tar.bz2)
The most notable things:
- Alt + F1 shows a menu with the key bindings (manually maintained via a textfile)
- Alt + 1…n draws up a rxvt instance ssh’ing to configurable hosts (see config)… couple that with ssh’s authorized-keys method, you have a 1-touch ssh connection service
- A horizontal conky instance at the top of the page (I can provide my conkyrc, too, if you are interested)
Have fun with it!
P.S.: I appreciate feedback (There be dragons!)
(Edit: Wrong URL)
Oh yes, there are dragons
I really like your colourscheme, for me the titlebars are a bit too thick, but then I’m a minimalist in that respect, it’s one of those things that drove me away from Enlightenment DR16…
I suspect you could create the keybindings dialog by parsing your FVWM configuration file with a script, hmm, maybe I should do that sometime
All in all I quite like it
ROFL even though I did not mean dragons literally…
well, yeah, I thought so, too. Actually, I was too lazy to put something together, but you are right, it seems doable (at least, in Perl g).
