I’m using panel and I wanted to know if there are some commands I can use for a key binding or in a function to shade / unshade a panel.
Thx for reply
Thx for reply
Assuming you mean a panel for FvwmButtons, then you can do something like this:
Key F A CM Next (name_of_panel, CirculateHit) SomeFunction
That sets up a keybinding, which you can change at your leisure.
Then you’ll need a way of simulating a means of pressing the panel button. Something lik ethis should suffice:
DestroyFunc SomeFunction
AddToFunc SomeFunction
+ I WarpToWindow 50 50
+ I FakeClick d 1 p 1 w 250 r 1
The only disadvantage is that the pointer is warped in order to simulate the click – you can of course mitigate this by adding another WarpToWindow command to the end of the function or a focus command, etc., to move it away as soon as it’s finished.
Note that also, FakeClick is not guaranteed to work.
Thx a lot ! works like a charm (except when I try to launch the function at init)
Yes, it would do. You would have to Schedule it.
Thx again for the step by step instructions
I didn’t try scheduling this command for now, I’ve just added + I Wait "program swallowed in this panel"
before I Next ("panel_name", CirculateHit) SomeFunction
Depends what you’re wanting it to do. I personally use Wait as little as I can in StartFunction since it can (depending on what ever you’ve asked it to load) pause for an annoying length of time.
But then it’s your choice. Ideally this should be added as an option to FvwmButtons at some point, although there are potenital issues in setting the geometry of the would-be swallowed panel button to ensure it opens up in the correct place.
In fact I wanted my pager and my taskbar (which are each a panel) to show when I start fvwm. The wait method is not clean, I agree, sometimes when I restart fvwm the FakeClick don’t work
Here is the code I’ve made :
[code]DestroyFunc PanelOpen
AddToFunc PanelOpen
It saves the position of the pointer before using FakeClick to restore them at the end
You can “invoke” it this way :
Next ("Name_of_panel", CirculateHit) PanelOpen
If you must use SetEnv, at least use UnSetEnv at the end of the function.
thx, edited
